A-pillar with air-bag trim removal
2007 Scout.
Give this a go earlier, in the same way as a non-airbag one. The Airbag logo is stopping the trim from coming away.
Any suggestions/ideas?
There is a screw behind the logo.
Sent from my Nexus 4 using Tapatalk
Aha! Thank you :)
Logo just pops off then?
Think so.
Yes. Pop it out with a small screwdriver or soft implement.
One edge is retained by a tag in the A-pillar I believe.
Jelly Snake - they're pretty soft?
Too soft!
Too soft!
But tasty!
The logo part normally needs replacing after it's been taken out.
Just be gentle...
Done. Thank you :)
Always very gentle in removing trim parts, saves trips to the dealers to spend money ;)
Am going to leave the trim off for a couple of days whilst things are installed (RVC, DAB aerial and DVR. Am going to tie-wrap to the existing loom to ensure there's no issue should the air-bag deploy too.
How far back does the air-bag go above the door?
