Any way to tell RNS315 to "set present location as a destination"?
Amundsen+ RNS315
If you were actually at a location you might want to return to, but did not have a postcode or street address (e.g. deep in the countryside), it would be convenient to be able to tell the system "Set your present location as a destination." From the handbook, I can't see a way to do that: anyone know if it's possible?
Regards, John Deas
Hi, you should be able to ...
When no navigation route is active and you only show the map, press the information button and a window should open with a lot of details about the present location; position, latitude and longitude, height above sea level, GPS status, the number of available and tracked satellites ...
In this window there should be a button called 'Flagged destination' which saves the current location.
This is taken from the manual, I haven't checked it in real life just now but I know that I have done it once just to try it out ... The key is to have no navigation active ...
Good luck!
