Metal pipes joining to the fuel rail
Got a question for a few.
On the 1.8T where the fuel rail is, there is 2 metal pipes joining to it, one from the charcoal canister and one from the water expansion tank, now im wondering where does the other side of that pipe go? (opposite side to the expansion tank, looking on thee pass side of the pipe.
From expansion to metal pipe then other end to turbo I take pipe
Coolant from bootle to metal pipe from metal pipe to top coolant hose
That metal pipe can be removed
Plug the evap to tip pipe and run pipe from header straight to top coolant hose
iv got.
Expansion bottle > bottom rubber hose > Y piece ( one to turbo/ one to block)
Top expansion hose > metal pipe on fuelrail... to where?
Top rad coolant hose plastic part
Just to the right of the inlet manni
Got it now.
Wasnt the coolant after all, was part of the charcoal canister. ill just block that off
