Multi Functional Steering Wheel MFSW Switches controls Paddleshift compatible
I have a set of brand new switches for the Multi-functional Steering wheel: £80
These switches have the input sockets for the paddleshift plugs - though they will work perfectly fine on a non-paddleshift wheel.
Believed to be suitable for the following vehicles:
  • Fabia II (2009 - to date) - from Build date CL 22/2009
  • Fabia II Combi (2009 - to date) - from Build date CL 22/2009
  • Roomster (2009 - to date) - from Build date CL 22/2009
  • Octavia II (2008 - to date) - from Build date CL 45/2008
  • Octavia Combi II (2008 - to date) - from Build date CL 45/2008
  • Superb II (2008 - to date)
  • Yeti (2009 - to date)
Part number: 5E0 919 719 B
NOTE - the part may require coding to your vehicle using VAG-COM, VCDS or dealer diagnostic systems.
Parts program states the above part number for:
Octavia 3 (2013 Onwards)
Good upgrade if you have a Octavia 3 SE as the blanks can be removed and these can be fitted in place
won't work in other models
Thanks - calling all Octavia 3 owners...! Anyone want an upgrade?
Bump
I have recently purchased a Octavia Estate SE 2014 & miss the steering wheel controls that I had on my previous vehicle.
Would these be suitable for my new vehicle & would they be a "plug & play" addition?
I am fairly sure from the advice given above that yes they will be compatible.
I think the should be plug and play but if not someone with VCDS or VAGCOM could do the necessary for you.
Still for sale...
Would these fit fabia monte tech?
Possibly. You will need to check the part number with Skoda.
Bump.... Open to offers...
bump
bump
Still available - and completely open to offers...
Since I see that you have FL Yeti does it fit?
would need one of those since I need Telephone function on my mfsw
If the part number fits...
Any idea if the blanks in a fabia SE just pop off? Or is it a steering wheel off job?
The part is only for Octavia 3
all others won't work properly
Cheers Eddie
This item is sold.
Guest
