Discs and pads
Want to replace all discs n pads on fab vrs , not sure wether to go for dimpled and grooved or oem, want the look if the dimpled but are they noisey, there are some on ebay from break depot for £139 all in
Its the pads that are the main source of the noise. I like grooved dics, not drilled, as the holes crack. I've not run dimpled discs. Often the best thing is to upgrade the pads, fluid and brake lines, and run OEM discs (as they're usually cheap). Performance over looks.
