Can't select gears
Don't know if anyone can throw any light on this.
I can select gears fine with the engine off, but once the engine is running I can't select any gear.
I'm suspecting this is an issue with the clutch (guessing it's a hydaulic one).
Can't see any leaks, but car is a 4x4 so does have a full engine undertray to catch anything that drips.
Thanks.
Might be a synchromesh problem - try selecting reverse gear, it has no synchromesh.  Can't get that either?  Possibly clutch drag.
Definitely sounds clutch related, it is not fully releasing to allow the gears to engage.
