Do you have a VCDS scan of a mkI vRS?
Any chance someone could fire me and Shinzagi a VCDS scan of a mkI VRS to have a look at the airbag coding?
I can when I get home from work in about 9 hours.
Is this all you need?
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 601
   Component: 31 AIRBAG VW51      0008
   Coding: 13105
   Shop #: WSC 31480
   VCID: DDBF1A4257CEAAF6501-513C
No fault code found.
Coding: 13105
Shop #: WSC 31480
Perfect, thanks.
Well Mine is:
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
So different Part No, Component and coding.
Here's mine:
Coding: 13105
Shop #: WSC 31480
VCID: DDBAA4A2575EC8F65F5-5120
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Don't panic; I disconnected the battery at some point in the path.
...So different Part No, Component and coding.
But is that for the car in your signature, which is neither a Mk 1 Octavia nor a vRS?
In a word, no.
I'm just looking to compare the difference between a mkI with and without seat airbags. My info is from our mkI Leon.
