Interior driver door handle
Hi does anyone know if the clip which holds the end of the plastic trim/interior handle is a replaceable part?
Apologies I know its not a lot to go on! AFAIK its a little white clip, its not visible unless you remove the trim and it holds the handle end in place.
I can get a photo of where its supposed to be if needed. Mines gone, just don't know if it snapped off or if it screws in or whatever?
Edited by acidstrato
I have a handle but there is nothing in the door card which the handle secures to? So I can lift the handle up out of place
yes the handle pulls upwards away from the plastic surround something seems to be missing from there.
here's a couple pics
oops ah I completely forgot about the chrome handle to open the door lol
thanks for the part numbers I looked them up and found a blow up diagram on some foreign site, I can see you have said its the "upper shell" trim but it doesn't look like anything has snapped on the end there?
could it be the "lower shell" 1Z1 867 175 C47H
ok brilliant mate thank you for that
Will have to get ringing around the stealers now
  • 4 weeks later...
Hi. Did you manage to find the clip that holds the handle in place. I have the same issue. It's not properly secure on the end nearer the back and lifts slightly, it also can rattle at times. Any help greatly appreciated.
