Fuel Filler Help
Just been washing the motor and whilst using the pressure washer noticed the fuel filler flap had sprung open, resulting in a quantity of water settling in the housing. Underneath the filler neck in the plastic housing there is a small rubber gromet with a hole in it that proceeded to suck the water out.
I presume this drain vents direct back to the outside and not into the tank.
TIA
TIA
As far as I know this just overflows onto the ground behind the rear bumper.
At least mine seems to when I was this area.
Always give it a little blast with the airline when checking the tyre pressures, make sure its not blocked.
The above is correct, it drains to the floor not back to the tank.
Thanks guys, thought that would be the case.
