Reverse Camera Fitting Guide for mk4?
I have bought and successfully installed this one https://www.aliexpress.com/item/1005006263043091.html it should be the same one and OEM! The seller referred me this manual https://aiduauto.com/blogs/installation-manual/skoda-octavia-mk4-evo-rear-camera-install?srsltid=AfmBOor_4VQeI-8HV9o051odIiFk-0o78mooUIBaezjqMjpBkbpe8d1o
For disassemble interior I have followed this guide https://youtu.be/rWVycZsKrEU?si=EgI1TYuyRBRKmzvB
It was quite a strenuous job and I wouldn't attempt it again, however camera fits and works excellent just like original, a big improvement IMO.
PS: be extremely careful when disassembling tailgate wiring grommet clips.
Edited by mmt
Thanks! That looks great! Did you have to do coding to the car?
Yes, adaptations and coding via OBD11 pro subscription needed
Hi, what instructions did you use? All 3 pins to connector under steering wheel or 2 pins to connector and 12v pin to fuseboard? Thanks
Edited by Weeguy
I connected on my mk4 2020 all 3 to gateway t32 connector but I got plans to connect red wire to fuse box probably when I will be doing heated steering wheel so you can use both methods
Thanks pins 1,6 and 7?
yes
Hi thanks again for all your help.
I have a 23 plate mk4 octavia and pro obd11.
Is below the only coding required?
19 Gateway Configuration:
Byte 15 : Change 02 to 12
Byte 16 : Change 01 to 51
Byte 18 : Change 10 to 20
Byte 20 : Change 00 to 02
5F — Adaptation Settings:
function_configuration_unit → Select RVC_video_input
Change FBAS to Ethernet
Car_Funktion_List_BAP_Gen2_VPS_0x0B ------ Switch to activated
Car_Funktion_List_BAP_Gen2_VPS_0x0B_msg_bus ------ Choose "terminal 15"
And
6C is coded to
Octavia MK4 NX  : 03032200A53000
Gateway 19 -
paco_video_parksystem-RVC_compact_smart
Multimedia 5F - adaptation
Vehicle function list BAP - VPS_0x0B (activated)
Vehicle function list BAP - VPS_0x0V_msg_bus (Can_fas)
function_configuration_unit - RVC_video_input (ethernet)
parkingsystem_video_input - carrier_resolution (1392x656)
6C
0303A300E73000 {that’s mine)
what I found iin 6C that only Brand (Skoda Audi etc.) and equipment_driver_side can bring you error and stop camera working
rest either it works or it doesn't but you still got picture
I struggled with my camera for few weeks I couldn't solve incorrectly coded module error i tried all coding
on the end I had to flash new dataset
I’ve brought a camera kit from AliExpress and will be fitting soon
I can code and remove SFD
Done a few Audis
So this should be easy
