DAB Aerial Connection
Hi guys,
Fitted a DAB head unit from a MK5 golf... (I think) RDS510?
All in no worries... But I need a live connection with ignition on for the Aerial...
Anyone know which wire I can use? Octy Mk2 PFL.
Ta muchly.
Worth checking if you can switch coaxial power on/off in a setting, as I understood lots of dab radios antenna's are powered via the coax?
I know this is defo the case with my Kenwood head unit there is an option to switch off/on the antenna power. There is no separate power cable on this type of antenna.
This is the sort of antenna on the Kenwood:
http://www.caraudiodirect.co.uk/dab/antenna-cables/kenwood-dab-a1-dab-glass-antenna
May be suitable for your radio?
If you have this one it is powered from a separate supply but has a the option to power up the coax too (provided your head can do it)
http://www.co-star.co.uk/prod/3744/dab-glass-mount-film-antenna-terminated-with-smb.html
Edited by Defenderben
