Couple of questions
The first is to do with the intermittent wipe ,is it just mine or does the switch to vary the interval seem to do nothing :( Came home this evening in very light rain, but the wipers just seem to carry on for a long time, then would stop for a short while.. then carry on... tried moving the switch but it did not seem to do anything...
Second, as I have a very poor memory, I went out to make sure I had locked the car... the red light was flashing on the drivers door, but I also noticed that hazard warning switch was flashing but very faint...anyone else have this?
Yeah my auto wipers are a bit rubbish too. Tend to use the manual wipe (stick down)
My switch does work on the sensitivity though with fewer wipes the further it is to the left.
Never noticed the hazard thing before and its chucking down here so maybe someone else can check...
Sent from my XT890 using Tapatalk
I use the auto wipers all the time and find them quite good.  The sensitivity works fine but I normally leave it on the far right setting.  Is the sensor obstructed in any way?
Never noticed the hazard lights switch before but do you have an alarm fitted?
The faint flash was not the result of a faint reflection from the first, I am presuming at this point that it was at night and therefore dark. If not night time please ignore my comments.
Funny enough that was when I noticed they seemed to work better, if I put the switch to the far left which should be the shortest interval it seemed to work, I then moved it gradually to the right but it seemed to work less...Will see next time it rains, maybe because it was constant drizzel...
Yes it was dark, but it was the triangle that seemed to have the faint flash. not sure if anyone can look when it's dark I would appreciate it :)
With regards to the faint flash on the Hazzards button, mine does he same. Can only be seen when its night time.
Thank you :) just thought it looked odd ...Lol
