Changing from a Stream to Alpine head unit what aerial lead
The car is an 05 Mk II Octavia
The unit going in is an Alpine CDE-173BT
I'm confused a bit about the swap.
I know i needs a facia adapter for a single din and was going to order this 1
www.caraudiodirect.co.uk/install-adaptors/skoda/octavia/ct24sk02-facia-plate-for-skoda-octavia
And this adapter http://www.caraudiodirect.co.uk/install-adaptors/skoda/octavia/ct20sk01-harness-adapter-for-skoda-octavia
but there's 3 aerial conectors
1 http://www.caraudiodirect.co.uk/install-adaptors/skoda/octavia/ct27aa08-aerial-antenna-vag-active-din-adaptor
2 http://www.caraudiodirect.co.uk/install-adaptors/skoda/octavia/ct27aa15-aerial-adapter-for-citroen-peugeot-skoda-vauxhall
3 http://www.caraudiodirect.co.uk/install-adaptors/skoda/octavia/ct27aa14-aerial-adapter-for-citroen-peugeot-skoda-vauxhall
I also read that i will have to run a switched power supply from the fuse box to the radio/aerial ?
Heres the conectors im working with [Thumbnails] and i know i'll lose the CD changer
Well, it rather depends on the aerial connector on the new head-unit. It will be either 2 or 3 on your list.
Running a switched live it not a problem, just test one of the empty fusebays in the fusebox and use a piggyback or spade connector and in-line fuse. The underside of the steering shroud is held on with 5 or 6 screws.
You'll need to do this anyway for the new head-unit as there is no switched live in the quadlock (OE units are controlled by CANBus commands).
Ok i piked everything up today and did a test fit.
On the ISO adapter should i leave red to red and yellow to yellow ?
can i conect the aerial to the blue power ant comeing from the headunit ? Or run a switched power from the aerial to fusebox
The switched power to the headunit from the fusebox what do i conect it to on the ISO
