Rear near side window slow to go up
Have done a search but couldn't find anything. My rear near side window is very slow to go up and close. In fact if you do the auto up it doesn't like it and activates the anti trap thing and goes back down.
Could the regulator be on its way put or is it just a case of taking off the door card and having a look inside?
Sent from my iPad using Tapatalk HD
Edited by aldouk
Is it sticking on the runner guides, get some holts or similar nylon and rubber spray drop the window and give the runners a good spray and lift window up and down a few times.
Then just wipe access spray off window its a cheap fix if it works, i spray all mine regular especially with the hot days we have had.
Thanks, will I have to take the door card off to get closer to them?
No just give them a good blast they go dry hence the sticking or binding.
then put them down then all the way to the top and keep holding the switch for a few more seconds--should reset
