Rear Brakes
Hi guys, just ordered some replacement front discs and pads for my 2010 vrs (cr170) and have just noticed the rear pads are looking quite thin so popped along to the ECP website to order up some new rear pads and got totally confused as they list several different types???? can anyone link me to the correct ones :)
Thanks for that, looking at my PR code (1KT) I need these http://www.eurocarparts.com/ecp/c/Skoda_Octavia_2.0_2010/p/car-parts/brakes/brake-friction/brake-pad/?101441778&1&b163d477fea4db39ee4b3ca688c190afef8f9b48&000036
but looking at my pads they look more like these
http://www.eurocarparts.com/ecp/c/Skoda_Octavia_2.0_2010/p/car-parts/brakes/brake-friction/brake-pad/?101441178&1&be73573effaa1e9c5f456b28f11630c3709517b3&000036
Only because i can see pressed metal clips between the pads and the caliper.
ECP lists these as being for 1KF and 1KP??? slightly confused lol
Oh and i have red calipers
Edited by ljphil78
I'll double check and get back to you in case I've made a mistake in the table.
You need to check the fitment on your car as I've checked again this morning and it could be 272 or 282 depending on if you have Bosch rear calipers which I suspect you do.
Edited by 0wl
I think thats the other thing that is confusing with these rear brakes, the discs that you quoted say 282mm but they also have a note saying disc dia 286mm???
Edited by ljphil78
unfortunately, sometimes you have to pull a wheel off & measure the rotors & take out the pads & take some photos & trace the outline onto some paper to sort it out.
Time consuming but not as time consuming as having to send back the wrong part
ljphil78, I've sent you a PM
