Fault codes
Sxfash
And what's it all mean lol Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NF
Component: 1,9l R4 EDC G000SG 5839
Coding: 00102
Shop #: WSC 13765
VCID: 68DF688A08E4595E337-4AE8
TMBWU46YX54256665 SKZ7Z0D2768986
3 Faults Found:
18097 - Powertrain Data Bus
P1689 - 35-10 - Implausible Message from Elect. Load Controller - Intermittent
19463 - Camshaft Position Sensor (G40)
P3007 - 35-10 - No Signal - Intermittent
19586 - EGR System
P3130 - 35-10 - Regulation Range Exceeded - Intermittent
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ASR80.lbl
Part No SW: 6Q0 907 379 AB HW: 6Q0 907 379 AB
Component: MABS 8.0 front H03 0001
Revision: 00000000 Serial number: 00000000000000
Coding: 0000008
Shop #: WSC 13765 000 00000
VCID: 7DF129DE2766ECF6F01-5140
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 250540 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0840
VCID: F2EB8AE2BE38238E1D3-5140
2 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25754
Shop #: WSC 13765
VCID: 3C77E4DA2CFC25FE87F-5140
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 11 AIRBAG VW51 0008
Coding: 12593
Shop #: WSC 13765
VCID: 1E330E529A2057EE89B-5140
No fault code found.
Address 17: Instruments Labels: 6Y0-920-xx0-17.lbl
Part No: 6Y0 920 971 S
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 28401
Shop #: WSC 13765
VCID: 4E93BE128A40A76E59B-5140
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 003D GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
VCID: F0EF80EAB034119EEB7-5140
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 13765
VCID: 6FED03962D0A8E6672D-5122
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 2Y Komfortgerát 0002
Coding: 00018
Shop #: WSC 13765
VCID: 3D71E9DE37E62CF6B01-4AE8
End ---------------------------------------------------------------------
AFTER
Saturday,30,August,2014,14:48:03:38786
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: TMBWU46YX54256665 License Plate: FV54NHF
Mileage: 251090km-156020mi Repair Order:
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBWU46YX54256665 Mileage: 251090km/156020miles
Coding: 00102
Shop #: WSC 13765
VCID: 68DF688A08E4595E337-4B00
Readiness: 0 0 1 1 1
Coding: 0000008
VCID: 7DF129DE2766ECF6F01-5122
1 Fault Found:
You might want to edit out your VIN from the VCDS output.
Looks like a problem with high pressure sensor. Look at the Ross Tech wiki for more info on that fault code.
I wouldn't too much about the others as they didn't come back. There was one relating to a low voltage, a poor battery, or disconnecting the battery, can lead to all sorts of faults popping up.
Sent from my Nexus 4 using Tapatalk
Is the high pressure sensor related to the sitcom as I've just swapped the engine and and have had the sitcom unplugged also is this the right group for timing 471788df9d5bf3866b10ed3b8846d3e4.jpg
Another quick one I've blanked the egr off one on manifold one on bottom of egr how do I get the eml to go off I've read about turning it down as I don't want to get rid as I want to keep the anti shudder valve
