Variable Boot Floor
I had a citigo with out the boot floor so retro fitted it by buying the parts from VW.
My question is, is this available as well for the Rapid Spaceback as the black doesn't have it??
Any part numbers would be a great help!!!
Believe item 7 is the variable floor;
Mounting points appear to be moulded into the standard side and rear plastic boot lining panels.
TP
Thanks TP
Would it just be part no 5JJ861529 i need??
Where did you get ETKA from??
Thank you!!
To be honest I've not seen a Spaceback with the variable floor but the diagram only shows item 7.
http://ifinterface.com/page/page3.php?langid=1
Select carprog 2 in the above link and change VW to Skoda in the drop down menu top left.
TP
I'd like a variable floor in my rapid... (Non-space back). Is it possible?
Anyone got an idea on the cost of the variable boot floor for the Spaceback - wouldn't mind adding it to mine as well.
Thanks for the link. But also - ouch. Bit pricey. Might not be an immediate accessory addition to mine, need to focus on more critical things first like mud flaps and a boot lip protector.
I agree, I chipped my boot lid on the first weekend we had the car! The paint seems a little thin to me!
125€ is quite a lot of money i agree...maybe it could be done cheaper with plywood?
a little diy project perhaps? :)
Edited by dukedl
  • 3 years later...
I  fitted  floor  in  boot  on  my  2014  spaceback  today,  18mm  mdf  cut  to  size  at  bq no  cost  exactly  29inches  by  39inches  covered  with  carpet  fitted  underneath  mdf  I've  enough  for  3  floors  all  cut  to  size,  £19.78  for  the  sheet  looks  superb.
