sd card stuck in bolero... help ;)
Hi guys. I bought my octy vrs 2011 in march and never used sd card. So i tough why not to try one. Because i have a loads of music on my phone i decided to use my micro sd card and adaptor to be able to play it in the car. First of all when inserted card i couldn't hear the "click" but all tunes went thru. So it works. But i can't take it out! I am trying to press it as it usually works but nothing. Trying to pull it. Still nothing. I don't want to damage radio or card... Any suggestions?
A gentle push towards the car on the card itself should be enough for it to spring back out again.
I have tried this many times but still nothing. Should be the same way as it is in laptop or any other sd devices but here doesn't work :(
All done. After 30mins of gentle work finally removed sd adaptor which was damaged and that's why I had problem. Thanks..
