Front door speaker help
Hi
Going to fit some new aftermarket speakers found out you can get speaker adaptor leads so i have been on ebay and i can not find skoda octavia ones witch ones will fit?
thanks a link to the right ones would be appreciated.
ps can i connect the tweeters the same way?
Don't know about the adapters mate, but if I were you I'd run new cables from your head-unit (or amp) to the speakers as the standard wiring is pretty naff.
Not too hard to do, drop your glovebox and lower section under the steering column and you can thread them through fairly easily, did it myself a couple of weeks ago. That way, you'll have the original wiring too in case you want to put it back to standard at any point.
