Arb bushes e.c.p
Just wondering if anyone has managed to get front anti roll bar bushes from eurocarparts?
Ive been through all the posts regarding what size diameter bush to get and am trying for a 17mm bush
The problem is on eurocarparts their system is trying to say its a 21mm internal diameter. Ive tried searching other vag cars and have found some for a golf which are 18mm and that seems to be as close as im getting.
Would an 18mm bush work?
Or does anyone know what car details to put in to find a 17mm bush?
It depends if the plastic sleeve is still in place or not, the 17mm bush is only used if the sleeve is removed, otherwise it's 19mm.
The plastic sleeve is the reason for needing to change, just seeming to be more of a pain than expected finding a 17mm bush
Try getting genuine ones from vw/skoda dealer, they are cheap as chips... Or even better fit polyurethane ones to prevent yourself having to do it again every 2 years.
I'll nip skoda shortly. Not keen on keeping the car to really justify getting poly's. Lol
Just need it fully & safely operational. Dont like thought of selling an unsafe car
Knock the sleeves off, repair any corrosion and fit 17mm
oem bushes all the way.....I had them on my car for 4 yers and replaced them because of the the time was long,but they were in very good shape
Edited by IulianE
