Running issues
Hi all the engine is running strange it's like it's hesitating and when I drive it pulls like a train till it gets to 3000 revs then it's like it just cuts out but have no fault codes and no lights are on https://vimeo.com/110582152
Sounds fine to me....
Look mate, they're golden, not crystal.
Seriously, anything we say is going to be a guess.
Having said that, even in the absense of fault codes, it makes me think of a bad plug or coil pack, or a fuel pressure issue.
Cheers guys it's going to mtec automotive on Monday anyway will see what they say
might be a vacuum leak somewhere in the pipe work?
Could be anything at this stage but my first call would be plugs and coil packs as said above.
changed both those yesterday put some redex in the fuel tank also not as bad now will see what's going on Monday and see what power it's putting out [emoji4]
You could try unplugging the maf see if it improves. It costs nothing to check.
yeah tried that mate unplugged most the sensors n245 n75 maf sensor etc [emoji17]
