Blower fan
Found out this morning my blower fan's playing up, its not speeding up to max when the screen buttons pressed any ideas, had VDCS on it and no fault found, so is it the resistor pack or the controller that has packed up?.
Everything else works fine and I can set it to max manually with the speed control.
TIA
Trev
Edited by Aston bodger
Any one?????
the resistor pack wont be an issue if you can get it to work at max manually. You will loose some of the speeds if the resistor pack has gone
