HMS Yeti!
Worth opening the Air Box and looking at the air filter, see if it is totally dry.
Thanks. Great idea - Will do first thing in the morning.
I had that when my Fiesta XR2 was nearly new. At one point all wheels were off the road.
The only thing that showed after was an occasional squeek from the clutch/release bearing for a few years in damp weather
I kept the car for about 12 years and 138,000 miles with no problems.
Strewth!!
That's deeper than I've been!!
Strewth!!
Indeed! It was an experience I would have gladly forgone.  I never want to be in that situation again.  I had been thinking of opting for an Octy Scout for my next Skoda, but the additional ground clearance available with the Yeti and its apparent near amphibious qualities have caused me to rethink seriously any future options.
Might you get it checked over by a qualified marine engineer?
You were lucky there - if the water was up to bonnet height, then it was above the height of the air inlet for the engine...
If it had sucked water in, it would have been instant wrecked engine, and a Yeti stuck in the deep water !
If you get the bow wave in the right place, just in front of the car, you get a hollow behind it that is below the air intake level.
The problem comes when you either go faster than the wave and it "breaks" continuously over the bonnet, or it suddenly gets deeper and the bow wave "sinks" as the nose of the car goes down.
The air intake tract of the Yeti looks quite good so it is possible that a "water trap" might have been built into it. Certainly the Td4 Freelander was like that. The bigger problem is getting water onto the ECU, as one member here found on Salisbury Plain a few years ago.
I've certainly gone through water over sill height, which is the approved fording depth. The door seals are very good!!
Having seen a Toyota pickup that did this, it is not something I would recommend. High compression diesel engine +water = expensive result.
There was a hole the size of my fist in the engine block out of which the piston was hanging on the conrod. They sourced a reconditioned engine (the pickup was quite old when it happened so no point in a new one).
The 1.8 petrol (as the subject of this tale) does indeed have a form of water trap inside the plenum box before the air filter. The lid is easily removed so you can see inside by gently springing the clips open along either side - no tools required, unlike the air filter box itself which never ceases to amaze me as it needs about 8 screws to be undone to get inside.
Of course, if the water level is high enough, then it could still overwhelm the trap.
Thought it might.
Thanks John.
