Skoda Octavia mk3 fl cornering light coding
Hi
I have Octavia mk3 face lift with front headlight with halogen bulbs and fog light also halogen. I curious if it’s possible to code cornering light on it? I have vcds. Also is there possibilities to code start stop function when stop?
Thanks for answers
Edited by Andriuzzs
Spelling
Yes Possible
23 minutes ago, Cairus said:
Yes Possible
Can you tell me what need to change in adaptation using vcds?
So maybe someone?
Sorry, i send you
15 minutes ago, Cairus said:
Sorry, i send you
Thanks waiting
Nö warrenty
Edited by Cairus
14 hours ago, Cairus said:
Nö warrenty
And how about vcds?
On 28/06/2026 at 22:43, Cairus said:
Yes Possible
Thanx
Picking up on this prior thread -
My April 2020 (last of the MkIII Facelift) Scout, with full LED package, has cornering lights on by default.
I sometimes would like the cornering lights to come on earlier in a turn; as configured from the factory, the cornering lights don't seem to turn on unless the steering wheel is rotated quite far from centre.
In the screenshots above, I notice fields:
Lenkradwinkel, offset (Steering wheel angle, offset): 0.3°
Unterer Lenkradwinkel (Lower steering wheel angle) 40°
Oberer Lenkradwinkel (Upper steering wheel angle) 65°
Do these control when corner lights turn on and off? Are they configurable?
Any warnings about setting them too low/high?
thank you,
