Help! 2008 Skoda hatch water leak!
My mother has a 2008 skoda hatchback with a water leak on the n/s/f seems to be coming from quite high up around about where the bonnet cable passes through the bulk head / heater motor area! cant seem to trace it lust wonder if anybody has any ideas ??  Its is not the front screen as it was removed and refitted yesterday due to the bond failing along the top of the glass!! this has helped a bit but still have a trickle coming in somewhere else in the upper bulkhead area Help!!!!!
make sure scuttle drain holes are clear as get clogged with leaves etc,, is a common problem on many cars/vehicles.
water should drain freely if you pour water into scuttle.
Yeah there clear got the scuttle panel off!! thanks
