how do u fix the mesh to my big mouth bumper..?
hi guys got some honeycomb mesh ready for the big mouth on my occty and the problem im having is the mesh i have is solid plastic so i can fold it around the sides of the bumper and tiger seal it like some have on here.. how would i fix it to the bumper its solid so cant be bent round.
any help would be much appriciated.!
I used the adhesive for windscreens by Kent autofix!
It was expensive stuff but even at 175+ it hasn't come off ;-)
mine dont fold round the edges so cant really be sealer around the sides like that
  • Administrators
Ah dam! Sorry :(
Tigerseal
Tigerseal
+1
would tiger seal work? my mesh is solid plastic so can be bent around the edges or nothing
If the mesh is plastic then would warming it with a heat gun make it flexible enough to bend? Then clamp it somehow while it cools before tigersealing?
Not a recommendation BTW, I've never tried it so please don't blame me if it goes wrong at all...
I used Tigerseal to hold on some abs plastic sill spoilers on my old primera turbo, when the guy that wrote it off hit it in the side, the only bits still solidly attached were the sill spoilers. :D
Have also used it to hold on boot spoilers - incredibly strong stuff if you use it correctly.
Tigerseal rules
Tigerseal rules
That is all ............. :D
Think I might cut it to size then cut a few grooves in the bumper feed abit of mesh through and then tiger seal it so it stays put!
If you use tigerseal, you won't have any problems with it staying put, just make sure where you put it as where you want it, because it won't be easy to change your mind later. :giggle:  Just put something heavy against it to aid the setting process if it has no support in that area.
