Temp Gauge Issue
Hi all, driving down to cornwall today on the motorway i notice the temp gauge dropping about a fifth below 90 then back up to 90? What would cause this??
Thermostat is my guess mate mines doing it also
Thermostat possibly - are you still getting hot air from the heaters?
It's more likely the coolant temp sensor, they are about £15 to buy and fairly easy to replace. Just make sure you get OEM/Genuine.
Thanks for the replies, i still getring warm air through the blowers....will replace both bits and see if that solves it :)
Oh! :notme:  Really so fairly can be located and replaced?  :peek:  :p
I bet thermostat is OK... first sign of dead thermostat is uneven and not HOT air from heating system.
Depends on your interpretation of fairly, but when I used the word I was implying on a garage carrying out the work meaning it shouldn't be any more than 30mins labour.
However after your help on my previous post I am able to locate my temp sensor myself and hopefully replace to which I am grateful.
I am almost sure its the stat but what else coukd cause this? Cts? Or something more sinister?
