Fuel pump hoses?!
Hi,
I have a mk1 vrs estate and have upgraded to a sytec fuel pump following remap.
I've had fuel starvation problems which I discovered was a result of a kink in the
Fuel line when putting back into the tank. I used standard fuel line from a motor
factors as I had to cut the original lines from the pump. I'm having difficultly sourcing the two
Fuel lines that connect the pump to the pump housing. Seems that you can't buy these
Separate from the pump housing?
Can anyone shed any light on this as I find it hard to believe.
Cheers, dan
