Problem shared is a problem...
Chaps and chapesses!
I have just had my Sony head unit fitted to my lovely Fab vRS :D
Slight problem, every now and again there is a crackle in the rear drivers side door speaker (the one near the handle i think) that gives off a crackle :(
Any ideas what this could be, and how to solve it?
I got cruise control fitted at the same time as the head unit if that's any good to any one? Could they be connected? The cruise works fine so i'm just thinking that there is a dodgy connection along the line...
I'd check the connections on the back of the Sony HU as that's what's changed recently :D If they're fine, check the connections on the rear speakers, but I'm assuming these weren't touched in the install? Can you make is crackle at will, or does it seem random?
Chris
I'd check the connections on the back of the Sony HU as that's what's changed recently :D If they're fine' date=' check the connections on the rear speakers, but I'm assuming these weren't touched in the install? Can you make is crackle at will, or does it seem random?
Chris[/quote']
Certainly random. HU out then :(
If you have the "hook" tools (<
