scan with codes helps
hi all got a problem with my cruise control and i had it scanned i have the read out below can anyone help point me in the right direction?
Saturday,21,February,2015,14:51:39:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: TMBBE21Z372064440   License Plate: H18GPP
Mileage: 146890km-91273mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 36 42 44 46 52 56 62 72 76
VIN: TMBBE21Z372064440   Mileage: 146890km/91273miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 021 LD    HW: 03G 906 021 LD
   Component: R4 2,0L EDC G000SG  8514
   Revision: --H05---    Serial number: SKZ7Z0F3834966
   Coding: 0000072
   Shop #: WSC 73430 790 00000
   VCID: 6CD7223B4F7E2C7E58B-8039
1 Fault Found:
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 146660 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:49:21
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.46 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8DA5776E8867E6AD9-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 J
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3D71DF7F648475F6BF5-8068
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004493410
   Coding: E18A8F030004140000110D000000000000087F075C
   Shop #: WSC 17009 576 03133
   VCID: 2B55E1278AF0EB46111-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 17009
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     031006 014  1201
   Coding: 00471077
   Shop #: WSC 17009
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0T2YYJ
   Coding: 0020788
   Subsystem 1 - Serial number: 6332MSME122536640
   Subsystem 2 - Serial number: 6342MSME124568165
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0002042
   VCID: 8109E38FD8FC51161BD-80D4
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
1 Fault Found:
00895 - Cruise Control Switch (E45)
            014 - Defective
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0F3834966
   Coding: 0007401
   Shop #: WSC 80093 222 69422
   VCID: 3979CB6F70AC49D693D-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001069051440
   Coding: 3D7F074007001303
   VCID: 2C57E23B8FFEEC7E18B-8079
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 145686 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:21:20
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 145686 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:21:23
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
   VCID: 2D51EF3FB4E4E5760F5-8078
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 E    HW: 1T0 959 701 E
   Component: Tuer-SG         005 0946
   Coding: 0001014
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 3561C75F5CB4ADB6775-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 01801A085283007F3F02050FC008DF96907C00
   VCID: 8305E987C2E04306091-80D6
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 145686 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:06:05
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 E    HW: 1T0 959 702 E
   Component: Tuer-SG         005 0936
   Coding: 0001014
   VCID: 3A7BD46375AA42CE9A7-806F
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3F0080022
   Coding: 0000402
   VCID: 2E53E833B9E29E6E36F-807B
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377DCD5746B85FA6659-8062
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
   VCID: 387FCE6B4BA650DE6C3-806D
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End   ---------------------------------------------------------------------
Looks like the stalk is defective. I wouldn't worry about the other codes.
so you would just say new stalk then? how do  know what part number ill need?
Search on here, it may be possible to clean it. Is it a pre FL car? If so I have posted the part number for the stalk on here before somewhere. Brand new one is about £60-70 IIRC.
According to this (http://wiki.ross-tech.com/wiki/index.php/00895) it may just be dirty contacts.
Quite common and full details of cleaning it are in the Octavia section on here.
I'd try that first.
I'd also clear all the fault codes and see if any come back. I bet the engine one will but will go after the CC stalk is sorted.
I don't think part number makes much difference in this instance. But do look at the images printed on it as these changed c.2010. Depends whether that bothers you or not.
i have cleaned the contacts and bent the pins to reposition them but still no joy. so i suppose i need a new stalk then i hve seem some on ebay for about £33 does any one know how much they are from skoda?
£60-70 as above. Possibly more.
I paid £25 for a used one two years back that worked fine. So £33 seems about right now.
There are cheap new ones on eBay for £30-40 but I think they can be of rather variable quality.
Can anyone tell me what cruise control from what cars will work in my octavia mk2 56 reg? As I wanna go to a scrap yard today and get a second hand one.
Well finally got the cruise control working.
80659825-B9F9-460F-BFC8-279C3AAA55DB_zps
Turns out it was the stalk got one for £33 off eBay brand new but not genuine one and it works. Anyone know if you can recon old ones at all??
