2014 roomster radio swap for dab
Hi all I'm due to take delivery of a new roomster SE which I think comes with the swing radio
I really want dab so found a seller on eBay who sell new rcd310's dab from ve
I know I need to add a foil aerial but what else is needed i mean will it need coding
I think the car also comes with parking sensors will these work as well in the display
I believe he sells the later unit with a different display colours
I can't stretch to a Amundsen as its leased and not sure if the next car will be compatible with an expensive unit
The rcd310/is cheaper than that
Nice bit of kit that though
Forget the foil antenna. However much you spend you will be disappointed. Rooftop is the only way in such a sturdy car as a skoda. If you have a pin number then you should not need any coding.
Garnett
I've got a foil antenna in my Octavia, my wife had one in her Mk5 (that I didn't actually earth), I put one in another lad's Mk5 and Johnny5ive has one in his Roomster with an RCD310DAB. So far so good - mine has been better than the £95 Calearo roof mount aerial I fitted, which lasted 8 months before water ingress killed it. If you buy the right one (the L-shaped Autoleads one from Halfords is ideal) they are amplified and phantom powered.
