Poorly Sick Octy...
Click Here
My poor Octy VRs :(
On cold startup, this happens.
Have tried cleaning the TB and aligning it with VCDS
Unplugged the MAF and it ran even worse so Ive eliminated that as a possible problem
Where to go from here?
Leaving the car to idle for 5 mins seems to clear it, and it runs reasonably smooth. Although when I press the accelerator it still hunts a little bit...
Coolant temp sensor is always a prime suspect for cold start up problems, one of the most common failures on VAG cars, & quite often doesn't throw a code. Have a look in VCDS engine measuring blocks to see what the ECU is getting from the CTS.
funnily enough one of the error codes was for CTS which I have ordered a new one.
How do I test it with VCDS? Im scared of pressing a button and my car blowing up lol
