First go with the DA
Brilliant work Damo
Well done matey!! :sun:  :dance:
That looks great.
Although it does look like you've only done half the bonnet!
I enjoyed my first go with a DA (borrowed from George. Thanks.) and will be back soon to give the Yeti a more thorough going over with a proper polish now I have a little more confidence.
Great work sir. Came up a treat. Bet the daughter is happy. One day I may splash out and have a try with a DA.
Great work Damo
nice job damo!
That looks great.
Haha it does indeed. I can assure you its the central bonnet crease and the angle as I was trying to capture the shine in the fading light.
I'll get a better pic if I get chance
Looks great! Well done now you will be hunting cars to polish.
Nice work. Im glad someone else agrees that Hell Shine Abyss is garbage, I hate the stuff.
Well, after glowing reports on here, I bought the little sample pot (25ml) and thought I'd give it a go.
I thought I must be doing something wrong, as it said apply and buff off after 5-10 mins. If I had have left it that long it would have been a nightmare to remove.
Gave it two minutes and test buffed, and even then it was really stubborn.
I wonder if it might have helped warming it up in hot water or something, as it was quite firm.
Anyway, I just reverted back to the G3 as I love the stuff, so easy to use.
Only thing I wasn't sure on is how best to clean the pads? I just ran them under hot water and kept squeezing them until it was clear. I wasn't sure if it was a good idea to put them in the washing machine or not?
Looking good Damo - nice work, and a good write-up! :thumbup:
Agreed, it is so fussy and the finish IMO isn't that great or worth all the hassle!
I clean my pads with fairly liquid under the tap and work it in with my hands till its clean.
Contrary to opinion....I love it
It buffs off better after 20 minutes Damo...It is quite temperature sensitive..It doesnt tell you this in the instructions
It took me a while to work this out too
Now I have, I rate it highly, but I can see why you may not..AB need to change the intructions
However, G3 is a nice wax..so no harm done
Awesome write up and results Damo. May I ask, did you use megs stage 1 and 2 throught the paint correction, or did you switch to another megs compound? (after initial testing of stage 1)
I always thought megs stage 1 and 2 were non abrasive compounds?
I used Megs Compound for the deep scratches and megs stage stage 2 on a firm pad for the swirls.
I then used Black hole to fill a few stubborn ones and then waxed.
Agree with ChrisRs about Hellshine being very temperature sensitive, it really works well on a warm summer day but the moment the temperature drops it is a pig to work with. The results do justify the product though.
Tony
I've not had any problems with abyss at anytime of the year, I prefer the paste to the liquid, but both work well for me even after 10 mind cure time, still my favourite wax.
Good job by the way it looks amazing.
