Fault Codes
Done and scan and got these
Engine:
P3255 - Oxygen Sensor B1 S1: Heating Circuit Regulation at Upper Limit, Upper Limit Exceeded
P1093 - Bank 1, Fuel Measuring System 2, Malfunction
Body/convenience system:
01135 - Interior Monitoring Sensors
Steering wheel:
00576 - Terminal 15
00883 - Ignition starter switch (clamp S)
00885 - Ignition starter switch (clamp 50)
Telephone:
01524 - Antenna for Telephone
Can anyone help?
Sent from my Galaxy S5
Have you cleared the faults and checked if they return? My old golf used to throw a lot of one off faults that never came back. Not had a play with vag com and a skoda yet but personally I wouldn't try and fix anything until I had cleared it and saw a repeat of the code.
I tried to clear but it wouldn't work.
What were you using?
Carista pro
Find someone local with VCDS would be my suggestion. The Ross tech wiki has a detailed breakdown on your codes, lots would seem to be wiring / connection problems so check for corrosion or bad connections.
The steering wheel ones all work fine. The antenna is because I fitted a RSAP unit where it had a HFP one. Going to disconnect bluetooth module and try again to clear
