Bluetooth retro-fit cable for use with 5K0035730D module and Swing
Hi All,
I need to retro-fit bluetooth to my wives Fabia Elegance with Swing radio, Maxidot, MDI and MFSW. I have a 5K0035730D module in my Superb which I will take out and fit to her car.
So I need a cable and am confused with the massive amounts of different cables on eBay/CarSystems.pl that may be suitable?
Are these suitable:
http://www.carsystems.pl/bluetooth-installation-kit-plug-play-for-7p6-and-5k0-module-foam-cover,id125.html
http://www.ebay.co.uk/itm/121276710166?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I dont know much about the Swing but assuming it supports BT, they should work. You might need your maxidot to display the contacts though as I dont know whether the Swing can do this. My guess is that if it supports MDI it will support BT.
You won't need the GSM antenna (with the maroon plug) for that module.
Thanks. I know about the GSM antenna as it doesn't do rSAP (but might be handy to have if I upgrade in the future). I have got maxidot and so should be fine to do all phone stuff through that.
