Water Orange cap thingy
well i've some how driven to college and to work and half way back from work to home my water thingy beeeped so all hell stoped car just to check under bonnet to see if anthing was low and well...there wasnt a cap on my water coolant buble holder ...
using plastic and an elastic band on it at the mo....
how much is a new one please :o
Your coolant header tank?
Plastic and a rubber band will not be sufficeint, needs to hold one bar pressure, you will boil over and overheat your engine.
How'd it come undone - usually they're done up pretty FT, to coin Ross' phrase
edit: You checked your engine tray its not fallen down? ;) Tap it from underneath see if you can hear it jumping about down there :D
Plastic and a rubber band will not be sufficeint' date=' needs to hold one bar pressure, you will boil over and overheat your engine.[/quote']
its only temporary i need to get one tomorow but i need to know how much they are :o
