Octavian mk2 abs pump
hi dies any1 know if a used abs pump and module will need coding to my car or is just plug and play? And also do the part numbers have to match exactly mine is 1ko907379p but most I've found have same numbers but different last letter
Sorry it's a 2007 1.9 tdi Octavia mk2
Edited by Biggbobb
AFAIK the last letter is just the revision version so all 'should' work.
I've no idea if the unit will need coding.
