Fitting a MB Quart QB410 A active subwoofer - what cables and fuses?
Ive purchased and will be fitting a MB Quart QB410 A active subwoofer. Ive purchased a Vibe Slick 8AWG 1500 watt wiring kit and a Quick release plug.
The active sub has a 20 amp fuse while the wiring kit has a 60 amp fuse. Is this going to be an issue - ie do I need to change the wiring fuse to 20 amp of replace wiring with a lower rating kit?
I need help please?
The spec of amp:
Output Power RMS ....................................................................................................................................................................150 Watts
Output Power Max. ....................................................................................................................................................................300 Watst
Lowpassfilter ................................................................................................................................................40 - 180 Hz @ 12 dB/Octave
Subsonicfilter .............................................................................................................................................fixed at 40 Hz @ 24 dB/Octave
Bass Boost .................................................................................................................................................................. 0 - 12 dB @ 60 Hz
Input Sensitivity ........................................................................................................................................................................ 6 V - 0,2 V
Operating Voltage ..................................................................................................................................+12 V (9 - 15 V), negative ground
Fuse rating ........................................................................................................................................................................................ 20 A
Dimensions (W x H x L) .................................................................................................................................................... 89 x 13 x 35 cm
The spec of Vibe wiring:
  • 5 metres 8AWG power cable
  • 1 metres 8AWG ground cable
  • 5 metres RCA interconnect
  • 5 metres remote turn on wire
  • 2 x 5 metres 16AWG speaker cable
  • Mini ANL fuseholder
  • 60 amp ANL fuse
  • 2 x spade terminals
  • 6 pcs cable ties
