suspension on mk1 octavia
Need help  please had a bit of a missapp in my vrs just to say my front wheel is no longer straight
put a wishbone on today still not straight so i need a hub and a strut my local scrappy as plenty of a3 and leons but no vrs in would one of them fit?
Edited by x_cupra_rich
Which hub do you need? As I am breaking a vrs at the moment
drivers side front sturt and hub
Shock absorbers should be replaced in pairs on the same axle.
You might need to replace the steering tie rod/rod end too if that has been damaged.
As vrstom said you should really replace both struts at the same time.
And I only have the drivers hub left over of you are interested
