Hub nut for vrs?
Is it a 12 point 30mm deep socket I need?
I can check at home tonight. It's definitely a 12 point and pretty sure it's 30mm. I don't recall buying a deep socket although at that size the bit is a good 2" deep which is fine for hub nut
Cheers son, think I've found a proper job on ebay, just wanted to check before I splurge.
Actually while you're here Jason, do you know of any n/s driveshaft in good nick for my car? Willing to try a whole unit to fix on the cheap, it's my inner joint that's going.
