Octavia VRS Diesel 2008 - Rear Brakes
Hi
Need to replace rear disks and pads.
Does anyone know what size disks are required?
Hi mine need doing as well it looks like there is two sizes for our cars i think 286 mm is common on the early vrs pd,s and newer cars seem to have smaller ones, i am going to remove the rear wheel and measure the disc,you could contact a main dealer and give the reg and they can tell u or there is a code in the boot on the big white sticker with all the cars codes.
Disc diameter is usually stamped on the outer ring of the disc rotor hub.  Also, the PR code for the rear brakes denotes the rotor diameter
