DSG paddle extension
Hi guys
Has anyone got these fitted to there paddles?
Keep thinking where they are worth it or not..I drive pretty much everywhere using paddles and my wife always moans that when she drives they are hard to use and follow the wheel rather than staying put do you think these would help...
What's your opinions??do the stick well??
I had some on my vRS but they were too close to the wheel and clicked against the stalks
I wouldn't recommend them at all
They make no difference as you still need to pull them near the base
A waste of money IMO
They fit better on VW's apparantly
Do yours hit against the steering wheel or not like chrisRs has said...I looked at that style but prefer the metal ones...but how well does it stick with 3m as worried if you apply top much pressure at the top will come unstuck
Oh right so if your where to use the stalks to flash or use windscreen washer then they would touch that's annoying as long as they don't change the gear...
They'd touch, only if you had the wheel turned round enough either direction where the tip of the extension is closest to either stalk.
For me, it's a non-issue. I don't activate my window washers or flash my headlights whilst taking a corner...
well that is very true i cant say ive ever done that before.. i think i will purchase some then.. i havent got an issue just my wife
