Best rarb to compliment R32 arb
Hey all. Just bought a r32 arb from a member on here. What rarb is good to use with it? Also what other handling mods are worth doing. I'm running on coilovers and I have a strut brace.
28mm Neuman brand I believe is generally accepted as best. edited with the correct brand now.
Do you have upper and lower braces? Both work well together. Could try TT bushes if you don't want polybush hardness and expense. Wheel spacers n all, don't need much to make a difference.
I have a tt upper strutbrace. Are the tt bushes any good then?
Pm Ian aka Meaty101 I believe he had them on his mk1. Try source the lower (S3) brace too, take out some subframe flex.
OK cheers
Ideally 28mm neuspeed or eibach 25mm
And a tt or s3 upper brace
TT cast arms
Tt hubs
Tt quick rack
Brace subframe
Lots can be done
I ain't got that sort of money lol. Have to stick with braces and roll bars for now I think.
