Hi can anyone help please
Typical I notice this on the hottest day of the year...
I'm not sure the last time the air conn worked as I don't tend to use it much.( with our weather !!!)
2004 2.0tdi no air cooling on air con .the light is on, pully is rotating on air conn pump.
I have read the havac code and it reads
00898-106
Control circuit a/c compressor
Sporadic 010 open or short to plus.
Tried clearing it but the code stays .
I've checked the fuses , wiring seems ok no chafing , checked the plug on the n280 seems ok
The n280 valve/solenoid does not seem to have a torx bolt in it but could this have some kind of 'cap' over the it to hide it.
If I could clear the code it worth disconnecting the plug to the n280 and then seeing if it come back is it another switch/wiring issue ?
I've read conflicting info as to whether these are replaceable.
Am I barking up the wrong tree ??
Oh I have just refixed the ambient temp senso by the lower grill as I had an encounter with a deer and it must have got dislodged.
Colin
