AC blower
hi anyone who has a wiring diagram on the ac on a octavia 2.0 tdi bkd my fan not run do not know if the relay or fan
best regards
The fan doesnt run if the A/C isnt working. Get the A/C working and the fan will work.
Check the fan when the car is hot + the cooling fan will be working. If its not then you have a fault with the actual fan. The small cooling fan controls both fans and these are common for faulting on the earlier mk2 octys.
But make sure its not just the A/C not working. When the A/C isnt working the fans dont work. Either there isnt enough A/C gas to work or the A/C pressure switch is faulty so its reading "not enough pressure" when there is enough pressure.. or the Compressor is faulty so not creating enough pressure :thumbup:
ac working after i have change the pressure swicth. but i get 24 bar on the high pressure side because the fan doesnt run )-:
So its just the small fan thats not working? What year is your octy?
yes its 2006
