Oily Bov - whats the cause ?
Hi, i just bought mk1 Octavia vRS, was just checking under the hood today and i noticed the blow ogg valve had some fine light grey oily thing in it,
what is the cause, the turbo seal going ?
see the pic
i failed to take the pic so you can see inside it tho
http://postimg.org/image/ort7o4ovb/
You'll always have oil in the intake system because the breather system is connected dont worry about it. What you should worry about is fitting the correct dump valve for the engine. Needs to be a recirculating valve not atmo like yours
Thanks for this answer, so we are talking about i should get me forge 007p right ?
A forge 007 would work yes or the standard valve fitted at the factory is more than capable depends if you want bling or not.
Edited by BrownBarge
