Octavia Mk III vRS Estate Sound System Upgrade
Very neat install I like it.
Do you get any rattling from the rear parcel shelf and pull-out cover?
Hi, I have Octavia3 Scout 2016 with Canton ss and managed to disable it as I upgraded My system to Mosconi 6to8 DSP, 2x Mosconi One 130.4 for front active and rear passive and for the sub Mosconi 1000.1D.
Front speakers Gladen 165 Zero pro PP active, rear Gladen Zero 165 passive, Sub Gladen Zero pro 12".
It wasn't so difficult at all with VCDS:) Just need to have speaker adapter for quadlock connector and 10R 5W resistors between all + & - leads that goes to dsp input.
I stripped original speakerwires from doorwire loom and replaced them with 0.75mm2-> 1.5mm2 and 1.5mm2 ->2.5mm2.
Crimped new contacts to ends and then same gauge wires to amps in spare wheell well.
Speakerwires from doors to amps
Hi, I have Octavia3 Scout 2016 with Amundsen+Canton ss and managed to disable it as I upgraded My system to Mosconi 6to8 DSP, 2x Mosconi One 130.4 for front active and rear passive and for the sub Mosconi 1000.1D.
