Octavia Clutch issue / question
Looking for a little helpful advice
Cars a 10 Plate 2.0 diesel  Octy 4x4 although I believe the clutch is similar / the same in any other diesels of a similar age,  cars done 115000 miles
The car isn't used a lot often spending days standing & recently the clutch bite point has been just off the floor but , there's no judder or slippage
Ive assumed its a hydraulic issue as it did get a bit better if you pumped the pedal.  Ive also had a few occasions when the pedals stayed about 1/2 way down & Ive had to pop my toe under it to pull it back up.
The slave cylinder is inside the housing so I had decided at 115000 pull out the box, fit new slave , clutch & probably flywheel & a master whilst its out but its a hefty bill.
Im wondering if the knowledge base here may have any other ideas & could it be the master cylinder. Im not heavy on clutches, my old Octy went to a friend & despite being mapped is now well over 200K on the original clutch ( 160 K by me ) so odds are it wont actually need a clutch for a while
The strangest thing is yesterday after a trip to get the MOT  the bite point came up to near normal
Any thoughts , ideas welcome
Have you changed the fluid for starters and bled the system?
Sent from my D6603 using Tapatalk
  • Decided to take a chance on a new master, bleed & fluid.  If that doesent work its slave & new clutch whilst its out ( & I guess flywheel )
Worked for 24 hours now clutch back on the floor so bite the bullet & get slave sorted & throw in clutch whilst its out
  • 2 months later...
Stuart J did that sort the issue out in the end?
