New engine and misfire
Need a little help from you guys, driving home about an hour ago and the EML light flashed about 6 times on 2 different occasions but within the space of 15 minutes. I've plugged my VCDS in and it's logged misfire on cylinder 2 & 3. I've only had this engine replacement in for 2000 miles and wondering if the spark plugs are brand new when they did the engine replacement or if they put the old ones back in? Need to use the car tomorrow for work and won't be able to ring until the morning. Am I best ringing the dealership first or Skoda customer services? Thanks.
Best Call Skoda UK Customer Services and get them to tell you what is on the Invoice for the Warranty work and if New Spark Plugs are.
Then its going to have to be the Dealership.
The Ignition Coils will not have been replaced.
You have had enough misfires to log codes, but i would have expected the misfire in cylinder 3 to have caused the shutting down of Cylinder 2 and to Disable the Turbo Charger.
Hopefully just the one plug fouling, or the Ignition Coil gone.
Cheers for the quick reply. Ive stored the logs but cleared them and went for a run on the motorway and nothing came back a part from 1 thing.
What came up at first
4060 - Cylinder 3
          P0303 00 [101] - Misfire Detected
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 115307 km
                    Date: 2015.08.09
                    Time: 04:02:13
4057 - Cylinder 2
          P0302 00 [101] - Misfire Detected
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 115307 km
                    Date: 2015.08.09
                    Time: 04:02:13
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [101] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 115307 km
                    Date: 2015.08.09
                    Time: 04:02:13
Ive cleared these and this has come back.
1 Fault Found:
4270 - Turbocharger Bypass Valve Control Circuit
          P0033 00 [101] - Malfunction / Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 115364 km
                    Date: 2015.08.09
                    Time: 05:34:07.
Ill be giving skoda a call first thing in the morning.
