Mk1 VRS - indicators not working (stalk / relay replaced)
The indicators on my 02 VRS have been playing up of late. I replaced the hazard/relay switch, which didn't fix the issue and have just replaced the column stalk. Both new OEM VAG parts.
They still don't work so I suspect there maybe a wiring issue but would appreciate any advice on where to look next.
***EDIT*** The hazards work but no indicator function on the nearside.
With the ignition off, moving the column up or down activates the parking light feature and warning buzzer.
Edited by modra_vrs
The hazards work fine but the indication is dead in both directions.
However with the ignition off, moving the column up or down activates the parking light feature and warning buzzer.
Do the hazards flash?
Have you checked fuse 2 (10 A) which supplies power to the direction indicators?
Did you buy a genuine VAG hazard flasher?
Thanks for your reply. The fuses (2 @ 39 for hazards ) are fine, O/S indicators function on hazards. All brand new VAG parts. Stumped.
